Hey guys wanna help me find, or if you stumble across
SigSaurP229
Another 16- 18 SuperSport, must be outboard powered, 70hp or greater prefered. Within 250 miles of knoxville tn. $1500.00 range or so. Obviously could care less if the hull is trashed but needs good outboard power.
Bluefin, Spectrum, Starcraft are all ok as long as outboard powered.
dozerII
Re: Hey guys wanna help me find, or if you stumble across
Hey Sig, are you admitting to MBS, before you have it???:bounce: I have heard EZ tell people to stay away from Spectrums.
classiccat
"Captain" + Starmada Splash Of The Year 2020
do Sylvan and/or Sea Nymph make-the-cut?
Edit: Not that it would matter...slim-pickins in your neck of the woods Sig!
SigSaurP229
Of course they both make the cut they are tinny's
SigSaurP229
and this one is more going to end up being a flip boat
classiccat
GA_Boater
This seems to fit your criteria, don't know about distance - Greenville, SC. starcraft boat
SigSaurP229
Ga thats perfect ive sent the guy an email. Hopefully that works out as that140 would be perfect on my 18 my 115 will drop on the toon and my 70 will fit on that perfect for a flip boat
GA_Boater
Hope it works out, Sig. I posted her in the CL thread a coupla weeks ago. Looks like a project, but if the Zuki is a good one - Well worth making an offer. I wasn't sure on the distance, but it's about 200mi. A good day trip.
bob johnson
wouldn't it be way simpler and make life soo much easier if you just bought a motor??instead of trying to flip all the left overs into a sellable boat?? look for a 1995-2001 carbuerated ocean runner or ocean pro(Johnson or Evinrude).. they come in Intruder and fasttrak versions as well.... they are the OIS ignition 60 degree block motors.... they run hard and good. you can get them for $1500 and up usually
SigSaurP229
Probably but alot less fun.
And its alot easier to sell a motor with a boat attached to it than just a motor, not to mention easier to draw better $$ out of one.
64osby
He tells everybody to stay away from everything that doesn't say Starcraft. :laugh:
There have been a couple Spectrums here. They are a much like 73chieftain's Mirrocraft, weak from the rib stand point. The older the better from what I've seen.
jbcurt00
Looks like good possibilities!
Be sure to check that all that unprotected plywood isn't weathered PT....... Might have an aluminum tank below that huge deck hatch..
^^ plus any other items you can nit-pick to lower the $ :)
Good luck. I was @ 2hrs from it Wed afternoon............
GA_Boater
Hear back from the seller, Sig?
dozerII
Heck no the more everyone stays away from the Starcrafts the more I can bring up here.:canada::D
jbcurt00
Ad's still posted, might bump the seller again.
GA_Boater
Since he doesn't have a number to call, email is the only way. Try this; Change the email title from the standard CL title to Hey, do you want to sell your Starcraft? Something to grab his attention if he checks his email.
jbcurt00
psst: Over here in the weeds....
1963 Starcraft Starchief OR 1975 Starcraft Islander?
I know a 1963 Starchief isn't what you 'were' looking for, but...............
It's a cuddy, and could certainly be family friendly...
How's a trip to Georgia sound? @175mi +/- :happy:
