hear is what was wrong after honeing all 5cyl new rings every thing looked good first thing I ck was compreison 126 127 across the board but as yall no i had the bad mis and did not want to idel very good thoght it was electrical at this point changed out stater,trigger,power pack and ignition switch it was none of the above I hooked up a regerlater and gages on my air hose shoot each cyl 40psi as i turned the moter at flywheel with ratchet puting presser as i went to TDC you could see the secound gage bleed of on #1 cyl and even werst on #5 you could also hear it bypassing in #5 hole so this tells me compreison gages even good brands or totaly not dependebale in some cases even now the gage steal is reading 127 in #5cyl when you spin it over.
Thanks gays for all your tips and help Garry
