I am using a 1997 Mercury 15 HP outboard with electric start. No problem starting hot or cold. My problem is when I give it throttle right after I start the engine, it will hesitate and stall unless I back off on trottle. I tried pumping primer ball as I advance throttle but does not help. I replaced gas hose line with new one just in case air was leaking, no help. After engine warms up it is O.K. Same problem occurs after fishing for half hour with engine off and than engine is started again.<br />Please help. Thank you.Please help
