After reading the typical seasonal "water draining" posts I got to thinking. How hard would it be for marine engine builders to come up with a mechanical drain to drain the block. Have some type of electric water pump similar to a builge pump and a switch on the dash marked "winterize." Hit the switch, pump the water out of the block, done. Of coarse it could include a "fill block" option for antifreeze just to make that camp happy.<br /><br />It just seems to me there has to be a better way then the present system. Not that I mind pulling a couple of drain plugs. With the amount of posts on the subject it seems not everyone wants to fool with it. I would be willing to bet with the low hours some put on there boat, myself included, that if all you did was drain the block every year and changed fluids every other year the engine would run just fine. Just my $.02.<br /><br />Jeff
