Tohatsu 9.8 has no raw water coming out the “pee hole”. Intake is clear. Path from bottom of muffler below pee hole is clear (water drains down and comes out intake and lower holes)
Other than impeller, could there be a simpler problem? Like blockage, but where?
Engine starts on first pull, runs smoothly, never showed any sign of overheating when problem was noticed, but I obviously can’t run it for more than a short test time (to see if water comes out) like this.
Any ideas before I pull the lower unit to check impeller?
