HELP
FFL_MOPAR
hi i have a 29 hp evinrude motor i have spark and fuel but wont start i can shut choke and try to start and it wont even make my plugs wet ? thanks if u can help me
rogerwa
Re: HELP
Try puttin a few drops of gas directly into he cylinder and then crank it. If it burns the fuel off then you need to look at the carb. This is assuming, of course, that you have verified the gas is actually getting to the carb. Also check to make sure you have compression to actually suck the gas in.<br /><br />If it is a fuel problem, disconnect fuel line at the carb, put it in a cup and turn over the motor, if you get pulses of fuel in the cup, I would bet your carb needs some indstrial strenght drano (please don't really use drano).<br /><br />If you get nothing, work your way from the fuel tank, pickup, anti-siphon valve, bulb, connection (not sucking air) fuel pump.
