I have a 1977 IMP with and OMC outdrive. My electric tilt and trim failed yesterday at the lake when I was putting it back on the trailer. I can hear the pump motor (located on the front right side of the engine) but the outdrive would not raise. I see two small oil lines that come off the bottom of the pump assembly that look like they go to the motor mount...????....please explain this. I had to take the gear drive assembly apart on the outdrive so I could manually lift and tie off the outdrive in the upright position. When I pulled the cover of this off (4 bolts holding a 4" or so plate) water came out. Now...I'm no rocket scientist, although I do work for NASA, but I would think there should have been oil inside this seeing that it houses a clutch pack. Does this get its oil from the pump up on the side of the engine, or is that a seperate oil system by itself? Second, can anyone explain how this pump makes the gear drive assembly work on the outdrive? Maybe if I know this, I would be able to figure out why it's not working. Seems like the pump is not pressurizing what ever it needs to drive this screw drive assembly at the outdrive. I have attached 3 pics of the pump, the small oil lines going to the motor mount, and the gear drive assembly on the outdrive....at least I think they will attach.
Any help will be greatly appreciated.
