Help
bustab
Can anyone help me?
I'm working on a 140 4stroke Johnson with an over heat problem.
I changed the thermostat and impeller.
The top of the engine is getting hot while the bottom is staying cool.
What could the problem be?
I'm thinking I have to pull the power head to get the valve train off to have a look though i really don't want to have to do this.
Is there a valve or something that diverts water on these motors? i very new to Johnson/Evinrude and am a little nervous about taking the timing chain off and such to get under the valve train. Plus I don't have a manual.
Do I have to pull the power head to get the timing chain off to get the valve train off?
Any insight would be much appreciated,
Thanks,
wilde1j
Re: Help
You have a serious need to get a shop manual if you plan to work on the motor. BTW it's really a Suzuki.
kenmyfam
Re: Help
How was it before you changed the thermostat and impeller ???
bustab
Re: Help
It was doing the same thing before I changed them both
kenmyfam
Re: Help
Then it may be a blockage somewhere. Is there much water coming out of the overflow half way down the shaft. How is the tell tale stream ???
bustab
Re: Help
there is good flow from the tell tale...not sure about the overflow. where should i be looking for that?
bustab
Re: Help
I got some info on Suzuki 140. Not an OEM manual but we'll see.
I'm going to pull the powerhead today to see if I can find a blockage under the valve train.
