help
casey33
I have a mercruiser 3.0 L and it wont run in the water but it will run fine on the muffs checked the ignition systeam and its fine any ideas :mad:
JustJason
Re: help
Well... Define for me the words "checked the ignition system" and the word "fine" for me.
how old is your fuel? Do you have a seperate tank (like a small outboard tank) that you can put fresh fuel in and hook up to the fuel pump to test?
If you don't.... start with the basics... compression compression compression...
