HELP!! Yamaha 150 2 stroke 1994
esteym
Just finished my center conlsole project, pulled everything apart on the old (by the way all was working well). Installed the new one, hooked everything up (all plugs in place) and turned the key to the on position. Guages light up and go through their test cycle, oil pump is filling the oil tank. I try to see if she will turn over for a sec..... nothing. Tilt trim works.
I unhook all of the guages, nothing. I check all the fuses.. the 2 by the starter, all good. These are fairly new plugs and connectors. Nothing seems corroded. What do I do?
Thanks for any help
Mike
WillyBWright
Re: HELP!! Yamaha 150 2 stroke 1994
You forgot to connect the neutral safety switch wires from the throttle/shift lever mechanism. Or it's out of adjustment.
esteym
Thanks,
The neutral safty switch had dislodged from its spot. works perfectly.
