mac daddy 1977
- Jun 15, 2011
- 4
My problem is no speed now after a prop change.....I have a 1999 Seaswirl/Striper 2300 wacc hardtop pretty heavy boat, with a 2007 Evinrude 250 E-tec. the old prop only showed that it was 14 3/4" stainless steel. The boat would perform at 4800 rpm 35mph. I then lost the lower end after 370 hours, thinking that the prop may have been too much. I now have put a Michigan Wheel prop 15 x 17 aluminum on the eng. with a new bottom end. This is definately not right. Now at 5,000 rpm it will run at 21 mph. The top end now is 6,000 rpm plus.
Suggestions are needed now........
