ihaveabrownboat
- Aug 24, 2012
- 88
Hope I didn't screw something up. Here's where I'm at.
Using the in and out switch the unit had been going up and down no problem. Using the up switch and the out switch together had been bringing the unit to the trailer position no problem. The trim switch didn't work at all though.
I was told that to get it working I needed to adjust the limit switch on the left side. It was new and unadjusted so this made sense. I'd been given a 10 page installation and adjustment sheet with the boat so grabbed that sheet and now have a problem. The unit is now all the way up and won't go down no matter what.
I adjusted the switch all the way clockwise with the drive unit all the way down/in.
Then I raised the unit all the way up. After that I wouldn't move anymore. Not while manually moving the limit switch. Not by using any of the switches on the dash. And not while manually jumping the down solenoid. The hydraulic pump spins but the unit never goes down.
Now what?
Now what?
