1978 galaxie 22xl.
Just got my parts via ups from iboats.com
Question is, I am replacing the clear trim line from the trim pump to the lock out valve. How do I put this hose together?
Also, I bought the line from the pump to the transom plate I would guess it goes to, that one looks easy, just screw it in.
Now, is there a way that you need to fill the system with fluid and bleed it?
If there is, what is the way to do that?
THanks for any help!!!
