EcumSecumguy
Thread starter- Joined
- Oct 8, 2019
- 8
I have inherited a pristine 1.2 Sears 1974 outboard made by Tanaka. It is a TOB-12B. I have realized there are very few parts available to repair it. One issue i am having is with the ignition. I pulled the flywheel an cleaned and gapped the points which are in good shape. I set the timing as per the original manual that i have. I reassembled it and there appears to be a problem with the spark. It will light up a spark plug tester which has a bulb in it fine, but if i attach a plug and ground it and pull it will not fire across the gap. I went and got a Lisle spark plug tester which allows you to set the gap (.024) but it wont fire across this either. The coil and condenser look brand new. I tested the coil as best i could and the resistance at the recommended ohm setting on my multimeter seems ok. The capacitor (condensor) also seems to pass the simple multimeter test i found.
Any thoughts appreciated on this. It is a shame to scrap thus motor ut is a 1974 timecapsule I even have the original box.
