EastTexasBassFisherman
- May 12, 2010
- 9
Can anybody give me a step by step path to follow for adjusting the shift cable on my motor? I have a 1994 Mercury 40 hp on a 1994 Tracker Super 16 pro v-hull. I have recently replaced the lower unit on it and also cured a problem with it being stuck in forward gear. (thanks to another post on this forum) It is now working fine when in forward and idles fine in neutral, however when I put it in reverse it makes a grinding noise and produces little to no rearward thrust. I am a novice when it comes to motor repair but with the proper steps to follow I can get it done. Any help is appreciated. Thanks.
