Re: help with shaft length for a kicker
The example is measured at an imaginary horizontal line from bottom keel to kicker location to form a 90? angle. What counts is the transom height measured from boat's lower keel to upper transom not hull's less lenght to where kicker will be positioned, nobody is pretending to plane with such a smalll engine. Just to push in an emergency at the most 7 knots.
No need to google, this issue has been tested and talked about to near ad nauseam in the inflatables-rib forums, to make it short, the only issues using a long shaft engine on a short shaft transom will be: (1) increase water drag against leg if water is passing above small plate (2) have excesive leg water splash sideways or water entering transom through engine's sides, (3) prop nicks, prop shaft bends, leg damage while hitting objects boating on shallow waters.
Happy Boating
