Hello
I'm currently rebuilding a 1974 sears eska motor. (model #217 5949-1) Can someone instruct me how to remove the impeller from the shaft? There is a small hole on one side of the shaft just above the impeller????
Thanks in advance
the impeller just slides up the shaft, on my 7.5 anyways. there a pin behind the impeller that stops it from spinning on the shaft.
i just pry it up. but do as you will
