We have a Quantum 1800 xb (Fish and Ski), listed at 1625lbs, Has a 1991 force 120 hp outboard mounted. We are running 44 mph on gps with light load. currently has a 13x19 ss prop. Last time out was the first time that rpm gauge worked "correctly" It looks like its right at about 600 rpm ideling in gear, (1,000 in neutral) and if correct over revving to over 6,000 at wide open throttle. Does the speed sound right for prop/rpm/weight? If so should I go to a 21 or 23 pitch to bring rpm back to acceptable range? Currently very quick to plane, just worried about over rev, I don't believe there is a rev limiter on this motor?
Thank you
Thank you
