OK. We have a 2003 Crest 22' Family DL pontoon boat with a 2003 Suzuki DF60 outboard. We have 2 props...
Prop (A) is 3 blade aluminum 13.75 in diameter with a 15 pitch. It does have a chip in one of the blades, about .25 by 1 inch in size, roughly. With this prop the engine RPM maxes out at 4600 with a GPS confirmed 16mph top speed.
Prop (B) is also a 3 blade aluminum prop but it has no markings as to diameter and pitch. With this prop, the max rpm reached at wot is 4400 with a top speed of about the same, 15 to 17 mph with a similar weight load.
According to the engine's manual, the top operating range for this motor should be 4700-5300 rpm.
Can anyone suggest a properly sized/pitched prop for this configuration with the info provided? We'd like to stick with aluminum due to cost. Thanks.
