help with parts
shisco
hi! my name is stathis and im from athens greece. i have been reading the forum and just signed up. as it seems here in greece dealers aren't that helpfull and parts cost double the prices i'm thinking of ordering from the U.S. but i'm trying to make sure i get the right stuff. so, i have a 2014 tohatsu mfs15c tiller outboard on a 3,60 sib. i will be moving this engine on a 3,85 rib. what i want is to convert it to a 20hp and to be able to drive from a wheel. just that. no electric start or tilt, i will be doing that manually. so what are the exact parts i should buy to do this?
pvanv
You will need a 20 hp carb for the hp upgrade.
Steering will need a link plate and whatever linkage your wheel setup has (push-pull teleflex type, or twin cable "tiller cable") type. If you need throttle and shift, you will want the SRC kit for the motor, and an RC box for lever control of throttle/shift.
shisco
Yes i want throttle and shift. By any chance would anyone know the exact codes for the parts? And thank you pvanv!
pvanv
3BH031000MCARBURETOR, F15C (MF/EF)$288.62Low StockDelete
3BJQ838803R C FITTING PARTS (F9.9/15/18B-15/20C)$149.07NotesAvailableDelete
3E0849050MDRAG LINK ASSY$149.00AvailableDelete
3B7Q843403RC BOX, RC5B (MFS-15/18B2-15/20C-25B/30B EP) W/O PTT$496.83NotesAvailableDelete
3AD102050MECU CORD, EP & EPT$448.20
