I beleive I have a pre-alpha outdrive, except the drive shaft housing is a alpha 1. Am I correct till now?
Well I need to change all my belows, water pump, and trim limit switch.
as I understand I will order all parts for a pre-alpha. My problem with the trim limit switch. would a side mounted one fit in place of the top mounted one. I just cannot find them on sale. Most propably not!!
Any advise on removing the hinge pin. It is different from the alpha 1.
I found the following tools, that I beleive will be necessary. Here is the link
http://www.mercstuff.com/hingepintool.htm
Is the 5/8 Dowell Puller #1 is the correct one? or #2 is better in doing the job? Anything else I will need? I hope I can find replacement pins.
Thanks everyone for your help.
