Help with motor positioning???
steve forsythe
My boat will not stay on plane under 3500 rpm's. It might be underpowered at 23 feet with a 200. It takes almost full power to get on plane and then you can back it down but only to 3500-4000. Should i get my prop checked for size and pitch? It is stainless but i have no idea the size or pitch. The shop raised the boat on the jack and that helped a little but how do i know if it is in the right place? It is at 5500-5800 at WOT, and i am not sure if that is optimum for my motor or not. It is a 2000 carbed Merc 200hp saltwater series. If anyone knows anything to help me, let me know. Thanks.
JB
Re: Help with motor positioning???
Howdy, Purse Snatcher.<br /><br />What boat do you have? Do you know what HP it is rated for? Has it ever performed differently?<br /><br />Your engine is probably properly propped if you can get it to 5800, but your boat may be underpowered, too heavy, have a draggy bottom or just be a poor design.<br /><br />Let us know what boat you have and it's power rating.<br /><br />Red sky at night. . .<br />JB :)
steve forsythe
It is an irvette from Irvette Marine. Not a real large boat maker but a good design ive been told. It has a deep hull and is real dry in rough seas. How do i find out what it is rated for. I think 200-250hp. One tip you might be able to give me....do i want the motor trimmed all the way down when i am trying to get up on plane? Also, when trying to stay on plane at lower rpm's, do i want the engine trimmed all the way down or up a little?
JB
Howdy, Purse Snatcher. I didn't even think of trim. Glad you mention it.<br /><br />Once you get her on plane, trim her out a bit. That should raise your bow and reduce the contact area, increasing speed. Back off the throttle a bit and trim her out a bit more. <br /><br />It will take a bit of experimenting to find the best trim for your loading on any particular day. <br /><br />If your boat starts to porpoise you are trimmed out too much. That will certainly reduce the rpm you need to stay on plane. <br /><br />You may find that you can rev her well past the 5800 you were getting before. If so, go to a longer pitch prop.<br /><br />Let us know how it works.<br /><br />Red sky at night. . .<br />JB :)
steve forsythe
Thanks JB. If she goes too high do i need to change the pitch up or down to lower it. Also, can someone measure the pitch and then adjust it accordingly? Thanks again.
JB
Howdy, PS. Up. 1" for each 200 rpm you want to reduce top rpm.<br /><br />Red sky at night. . .<br />JB :)
