challenger88
- Jun 10, 2008
- 4
Hello...I was hoping someone could help me with a shifting question. I was on the lake Sunday and went to engage th engine. The engine revved but it did not engage in forward drive. I went to nuetral and then tried reverse. It did not engage right away either. I then tried forward one more time and it started to engage then stalled the engine when it engaged. I initially thought I was stuck in reverse but things happened so quickly I was actually in forward gear.
The control box would not let me shift into nuetral. When I got home I removed the shift cable from the shift pin. I thought I might be able to manually slide the shift pin into nuetral. I was able to set the control box back to nuetral and can see where the shift pin needs to line up.
This where I am stuck. I am not sure how to manual shift the motor. At the prop, I can spin the prop clockwisewith 1 finger. It makes a slight clicking noise kind of like it sounds when it is trying to engage. It does not spin counter clockwise. At the power head I can turn the flywheel clockwise with 2 hands and the prop spins clockwise. It is kind of hard to turn but I figure that's normal? Usually the starter or the rope is needed to spin the flywheel. I can't seem to get the shift pin to slide back to the nuetral position. I tried spinning the flywheel with my hand while trying to jiggle the shift pin towards the rear of the guide block but it doesn't seem to want to move. The shift pin attaches to a lever that is attached to the drive shaft ( I think). I wasn't sure if I should try to crank the engine and then try to slide the shift pin ?? Thanks for any tips or ideas.
