I have a significant leak in my aerator pump. Has anyone had this happen with this cartridge style pump before? I would like to know if this looks like I need to replace the entire housing, or if this is a common issue with just the cartridge and I would be OK to order the cartridge only. I’ve included a video below, you can see the water leaking out of the top and side notch of the yellow housing.
So strange this happened randomly, with no hard impact to the pump that I know of.
is there a seal in the cartridge that could of broken down and caused this?
The pump model looks like it's a cartridge style 750gph Mayfair Marine pump made by Johnson pumps.
Thanks for your help
