Help with Kohler 7.3E Generator
brownb01
Hello - I’m looking for some help with my generator. I have a 2008 Kohler 7.3E with 311 hours. Last season the generator worked fine – started easy and had zero issues. Early this season (before I ever started it for the season) I had the impeller and oil/filter changed. Several weeks later I went to start the generator, it fired fine and ran for maybe 1 min. It ran long enough for the air to start blowing cold out of the air conditioner. Then the generator died and would not start – the switch was dead, nothing - the motor wasn’t turning over…etc. I said the heck with it and didn’t mess with it for the rest of the day.
I start some basic troubleshooting back at the dock and the 10amp input fuse on the main panel is blown. I replace the fuse, and as soon as I hit the start switch – the fuse blows. However, there have been a couple of times I can replace the fuse and the generator will fire and run for about 15secs and then dies – with a blown fuse. It only seems to start for the 15secs after it’s been sitting for a few days.
I was going through the troubleshooting steps in the service manual and it kicks me out of the troubleshooting flow chart with “replace fuse”. Not real helpful. I was able to go through some of the other troubleshooting steps just to learn about the system. I was able to narrow the issue down to whatever is connected through the P2 connection on the controller board. With P2 discounted – I can push the start button and the fuse doesn’t blow. With P2 plugged into the board – the fuse blows right away. A few other things I’ve tried – I leave the AC circuit breaker off, and I’ve made sure to leave the generator breaker on the boat off. (both the same thing I believe) Neither one of these things produces any different result. I’ve also tried disconnecting the voltage regulator and I get the same result – blown fuse.
I also called a local marine service place and they weren’t to helpful. They did say they were able to disconnect the AC side of the generator and get the motor to stay running as long as the held down the start button. They quoted me $15K to replace it. (sigh)
The other thing I noticed while messing with it this weekend – is there is a wire on the side of the motor that is not attached to anything. I’ve included a pic. I’m not sure what this is or if it’s even a concern. It sure would be nice if all I had to do was reconnect this wire and my problems were solved! [FONT=&quot]😊[/FONT] (I’ll keep dreaming)
I would appreciate any advise on how to troubleshoot this or if anyone has any ideas on a solution. I’ve called another service place that is supposed to be pretty good with generators – but I’ve been waiting 3 months. [FONT=&quot]😊[/FONT]
GA_Boater
Is that a ground attachment point? Got a schematic in the service manual?
alldodge
Removing P2 just removes power from the circuit board. You could remove the board and try to follow the circuitry thru the components to ground, but this will be difficult. Like most manufactures their schematic diagram is not the best. I should be in your manual, but if not it is online.
Its probably the voltage regulator or relay interface board.
Note: Your not making it easy for us old guys to read your post when you change the font to a smaller one
GA_Boater
Fixed it for us old guys. :smile:
brownb01
Appreiacte the feedback.
Even with the voltage reg disconnected - the fuse still pops. Which, would lead me to believe it's not that. Yes / no?
As far as font - I didn't change it, at least not intentionally. I typed my message and hit post. The font looks the same as every other post when I view it.
alldodge
Agree not reg
Finding a short is ruff, and just takes time and the understanding of circuit paths. Looking at the schematic I'm having trouble finding some of the pin connection points.
brownb01
Agree not reg
Yeah, I was having the same issue when trying to go through the troubleshooting steps in the service manual.
Someone mentioned the relay board - is there a way to test the one I have ? I also don't have an issue buying one if there is a pretty large agreement that is the most likely issue.
alldodge
Only way I would know to test it is put it on a bench and use an ohm meter to trace the circuits, check diodes and relays. There is nothing ever found on web I've found. There is one test in the manual if the fuse is blown, but isn't real clear what the outcome would be. Figure 8-2 page 4/03
Have you tried disconnecting the remote panel and starting from the engine room?
brownb01
I've not tried disconnecting remote manual. Any idea where that connects? I'm guessing somewhere on the control board...?
