Help with ID of Evinrude
Packard8
Hi folks,
I've been offered an old Evinrude for cheap to use for backup parts for my Johnson 90. I was told via phone (the motor is 200 miles away and I haven't seen it yet) that the model & serial number are:
90483-S
E01797
Do these numbers indicate the year, model, HP etc?
Thanks in advance,
John
Joe Reeves
Re: Help with ID of Evinrude
90483-S = First numbers are hp, 3rd number is year.
1964 90hp Evinrude.
Packard8
1964 90hp Evinrude.
Thanks Joe,
My Johnson 90 is a 1982....will there be much on the 1964 Evinrude 90 that is interchangeable?....starter, lower unit, carbs etc? The tip of the skeg on the Johnson is broken off about even with the outer edge of the prop and I was hoping to swap the LU with the good skeg.
Thanks,
John
82rude
very few if any parts will interchange their 2 differnt animals.for one the 64 is a non-thruhub pin drive lower as the 82 is the exact oppisite .try to find a 81 and up omc.
Joe Reeves
My Johnson 90 is a 1982....will there be much on the 1964 Evinrude 90 that is interchangeable.John
No, sorry. Completely different animal. Nothing will interchange.
Packard8
Thanks for the info guys,
Not what I wanted to hear, but what I needed to know.....lol...:(
82rude
would like to see a pic of damage but i will try without.you can get skeg guards or as long as the welder has something to work with their easly repaired.
