Help with hydraulic line fitting please
ackman
'95 FORCE 70HP OB - I need to remove the power tilt pump and remount it to accommodate fitting the OB to a jack plate.
Without removing an existing hard line to determine the fitting (male flare type?) size, anyone know what it might be? I can order a fitting that installs in either the pump or cylinder to use as a pattern but my FORCE jobber says it might be a few weeks before I see it.
The hard line part # is either 32 - 819327 or 32 - 819328, and the fittings
22 - 48166 or 22 - 45794.
