garzaglass
- Feb 13, 2005
- 54
1978 75h evinrude
i cant get the engine to turn over at all. the starter does nothing like its not getting electric. i know the key works cause it engages the choke selinode when i push it in but wont do anything when i turn the key. i tried cleaning all the electrical connections and nothing. also tried another battery and nothing. it was working fine before i started doing maintenance on the engine. all i have done so far is remove, clean and install the carbs, fuel pump, and water pump. also i replaced the thermostat. the only thing i forgot was what looked like a grounding wire that went on one of the thermostat housing bolts. i connected it back and the engine still wont start. the only thing i havent got done is the choke linkage on the carbs. cant figure those out but i wanted to see if the engine would start while i manualy did the choke when i found out its not getting electric. please help im pulling my hair out.
