91 mercruiser 3.0LX
I was getting gas in the oil, a rather large amount. After searching the forum it seemed to point to the fuel pump. I replaced that, all seems OK now with that anyway. I replaced the plugs last week because of fouling, they were black and wet. That leads me to this.
New plugs in #1 and #4 were black, #2 and #3 were just like new. This was with only about 15 minutes running on muffs. I hooked a timing light up to each plug wire to check for spark. #1 and #3 had a consistent flash, #2 and #4 seemed to flash twice as much as the other two. What would cause this or is it normal with the DDIS ignition?
Compression was also tested all four were right around 165 (warm).
Thanks
Thanks
