deserttoad
- Jul 14, 2002
- 44
I was given a boat and motor from my grandfather about 5 years ago. He claimed it had just been gone through at the boat shop and was ready to go. I brought it home and put it in a bucket to fire it up. After a bit of work it ran with lots of smoke but settled down and seemed okay. Took it out to the lake and it ran fine for 30 minutes or so, then quit and wouldn't start. Pulled the plugs and they were fouled bad (TOP cylinder worse than the bottom). Rebuilt the carb - same prob.<br /><br />So I'm reading in my repair manual (Seloc), about how to synch inginition to the carb. It was way off, best I can do is within 1/8 inch of the mark.<br /><br />So now the question: would the synch cause this, or did I do a bad rebuild job?<br /><br />Also, the book claims a bad fuel pump will foul the top worse than the bottom plug, but it tested okay.<br /><br />thanks for the time,<br /><br />DT
