boltonranger
- May 2, 2004
- 204
The truck is at my work. It is a 1991 UD1800.
4 cylinder diesel box truck. Six wheeler.
I realize this is not a boat etc. but I was hoping you diesel fellows might help.
It is left to me to fix the truck - and I'm a diesel newb.
Symptoms:
Intermittent hard starting.
It will often start if left to sit.
Only once did it quit at speed.
Today it quit when the driver let the clutch out to move it.
Wouldn't restart though it tried and died after catching.
My observations:
There is a fuel water separator which is between tank and engine.
We (driver and I) tried to drain by opening valve at bottom of bowl.
When drain valve was opened; air was sucked into bowl rather than fuel or water draining out. This happened after much cranking; and could be duplicated. If left open long enough the bubbles traveling upward stops and a very small amount of liquid drains without fully emptying the bowl. (I can see it's still full.) I removed the fuel cap from the 30 gallon fuel tank to alleviate a tank vacuum condition but it didn't help.
My conclusions:
I think there should not be a suction at the drain. I think that not only that but also that the bowl should be willing to drain off when the valve is opened. I also think that the fuel inlet line to the separator must be clogged somehow either by a dirty screen in the tank itself; or by a stuck check valve in the tank or dirt in the line etc. (The fuel filter in the engine bay is new; was changed recently to hopefully stop this trouble but did not.)
My questions:
- Is it a common thing for this type of truck / tank setup to have any sort of fuel strainer inside the tank at the pickup?
- Is there a check valve normally found in the fuel pickup line in the tank?
- Should not fuel be free flowing from the separator bowl drain when opened?(regardless of any water presence.)
- Am I correct that the separator drain valve should not be admitting a stream of air bubbles into the bowl?
What can I troubleshoot on my own?
Are my above conclusions correct?
I'm grateful for any help you can offer.
br
Symptoms:
My observations:
My conclusions:
My questions:
br
