Help with a 2001 Wellcraft Martinique 2600 fuse panel
Jn1965
Hi,
I was working under the instrument cluster in the boat the other day and I noticed that on the blade type fuse panel behind the cluster, fuse #14 is missing. Does anybody have an idea as to what fuse 14 powers and how big a fuse should go in the slot? I cannot find anything related to fuses and sizes in the owner's guides to the boat.
Thanks!
jhande
First off, some missing info... Boat year, make and model.
Probably the best thing to do is look for any thing electrical that does not work. Then research how many AMP's it requires.
Good luck!
Jn1965
Good luck!
The title was " Help with a 2001 Wellcraft Martinique 2600 fuse panel" so I thought that would cover the year make and model :)
I am surprised that nobody published what the fuses in the panel do.
jhande
Dang sorry!
Some times my 62 year old eyes and brain don't work well with each other. :sick:
Sorry...
what color wire?
that will tell you what it powers
from there you can determine proper fuse size
Alumarine
Dang sorry!
Sorry...
I have the same problem when the subject line is not repeated in the message body.
That goes for emails or forum posts.
