Re: help with a 1975 johnson 65hp
Hi again Jparker 70<br /><br />I just gave your problem a couple of extra thoughts. The reasons for your problem can be several. <br />1: your cooling must work. If you dont know the impeller was changed within the last two years - do it. If it is the old cast pumphousing and its been in salt water, it will need a complete pump set. If the impeller should be fresh, try to clean the hose and pee-hole - maybe blocked by insects or so. <br />2:Has this motor sat ? If it has, it probably needs a carb clean, or better rebuild due to its age, jets can get a little varnished every year. Can you hold your hand on powerhead for 2-5 seconds without getting burned when it starts acting like it dies ? If you can it isnt heating up. If it does you have to check thermostat as well.<br />3:If above doesnt help, check compression. On a motor like your it should be around 120 - 150, but at least boyond 100 and within 10 PSI an all three. Do a little work and post back.
