hold em hook
- Mar 8, 2009
- 12
I have a 50hp evinrude, here lately it's got to where when you crank it up and run it then come to an idle it hiccups. It will sit there and idle for about 15 seconds, hiccup, idle, hiccup and then go dead. It will crank back up and run out through low to high rpms fine. I've recently had a new fuel pump installed, and carbs worked on as well as a power pack in the last year. Bad part is it was doing this before as well. Any ideas?
Thanks
Thanks
