help with 78 sea ray srv220, engine bogs down over 1700 rpm
tiremandan
well i am new here and am hoping to find the problem with my boat, its a 78 sea ray srv 220 with a mercruiser 228 i/o. it has developed(practically overnite) an issue with the rpms. it bogs at 1700 rpm and has started stalling at idle...i changed the plugs and fuel filter and was thinking the anti siphon valve but cant find the fuel tank....yup fuel tank....can anyone help me on this i am feeling quite stupid at this point, and where would the anti siphon valve be....just but this thing a month ago, and ran like new till last week thanks for the help
Re: help with 78 sea ray srv220, engine bogs down over 1700 rpm
Ayuh,... Sounds like water in yer carb....
Follow the fuel lines to find the fuel tank...
The Anti-siphon valve is at the top of the pickup tube...
tiremandan
Well thats not good....can i drain the tank through the filler nozzle with a transfer pump and effectively remove any water thats in the tank? i can drain the carb but that tank is really bugging me.
tiremandan
ok, here we go...I am still facing this problem and am ready to scuttle my vessel...(sell it) it srill loses power and dies after a few minutes(acts like running out of gas) It has a 1978 mercuiser 228(305 gm) it had the points removed by previous owner and electronic ignition installed(mercruiser kit). the following is all that i have done to it so far....
1. replaced fuel lines and filters
2. inspected and replace fuel pickup screen and anti siphon valve
3. fuel pressure tested at 6-7 psi constant.
4. replaced coil
5. replaced plugs, wires, cap, rotor...(plugs were wet)
6. cylinder compression test, was told all ok (not sure actual reading for each)
7. replaced temp sending unit and gauge...temp ok!(just in case)
8. tested fuel for water, all ok..tried using external tank with fresh gas...ran the same!
9. checked timing...6-8 degrees.....all ok
10. checked and lubed distributor mechanism under cap..all ok
11. check for fuel (after motor died) tried starting fluid...didnt help!
12. checked #1 spark plug after died....spark was intermitent/ inconsistant...
the only thing left that i knoe of is to replace the mercruiser kit that includes the ignition control module. it cost me 236.00 but i need to check it....the only way this thing starts is when it is cold then looses power and dies after about 5 min...if i let it sit for 1/2 hour then it will fire and run for a few minutes than die again... hopefully this new icm helps me. if anyone has any info please let me know.
tiremandan
1978 mercruiser 228 losing power/dies after 5-10 minutes
4. replaced coil
Re: 1978 mercruiser 228 losing power/dies after 5-10 minutes
Ayuh,... Have ya seen the diagnostic tree Don posts,..??
Test things, before ya replace 'em....
Let's ID this Mercruiser Kit yer talkin' 'bout....
Is it a T-Bolt IV up-grade, or a T-Bolt V up-grade, or,..??....
It does sound like yer headed the right way,....
tiremandan
akay
tiremandan
this kit is a sierra marine 18-5296-2 electronic conversion kit, it is the same unit that is curently in the distributor....fyi...it didnt work, it still won't run right, it barely starts so problem is getting worse.41+w5wrUxuL__SS500_.jpg
tiremandan
also i noticed lack of fuel in the carb last night, disconected gas line at carb and rechecked the little filter there and noticed no gas in the line coming from the pump and very little coming from the carb inlet. put pressure gauge back on fuel pump and turned over engine and it went to 5 psi(quickly) then dropped to zero 20-30 seconds after i stopped cranking, also checked the line to carb for any blockage, none found. noticed fuel pump was wet externally with trace amounts of fuel(before disconecting line). the glass fuel bowl is also completely empty...what is the purpose of this device and should there be anything in it??? any help is greatly appreciated. thanks
tiremandan
for sale, one used boat...no resonable offer refused...comes with oars and a headache.
Ayuh,.... What's this $236.00 part yer talkin' about,..??
You don't have a stock ignition, 'n I haven't done what you've got,....
I've either had points, or T-Bolt IVs....
It sounds like yer hittin' the bases,.. fuel pump sounds good...
Use yer timing light to monitor the spark, 'n advance....
Use a test light to monitor the power to the coil,..??
I donno how to test the pertronics stuff.... have ya been to their website, 'n poked around,..??
