I have a 1978 55hp Johnson that came on a boat I just purchased. For some reason the motor seems to load up and bog or stall often while at idle or low rpms. I changed the spark plugs which were very worn ( the metal piece that sticks out from the side under the electrode was noticeably warn down) and I noticed on the coils that the plastic part where the plug wire comes from which is attached to the metal bar that bolts to the engine seems to be loose and can wiggle some where the top cylinders coil seems to be tight. Is that bad? As long as you keep it above a idle the outboard seems to run good.<br /><br />Right now I am thinking rebuild both carbs and one new coil
. Anything else I should look into?<br /><br /><br />btw, it is a 2 cyl not 3
