matt-fortmyers
- Jan 2, 2011
- 4
I just bought a 67 6hp Evinrude and it runs well. I was happy to see that so much support is available through this forum. I'm completely new to outboards. I have some questions-- any support would be appreciated.
I'm running it on a 50:1 mix but I'm using 2cycle oil for air cooled motors (not marine grade). Do I need marine grade?
I'm running it in salt water. Do I have to regularly run fresh water through the engine?
What is the best position for the mix? It runs best turned almost completely down to 0, but this seems wrong to me? Any suggestions? It does not idle well and I feel like I'm putting into gear with the throttle far too close to the Start label.
Any other advice regarding this motor would be greatly appreciated!
Thank you kindly,
Matt
Thank you kindly,
Matt
