Help - Wiring?
CZSteve
Re-Assembling this motor and I have 1 wire I don't have a clear picture as to where it belongs.<br />The boat is a '77 Sea Ray (SRV 197) w/ 5 litre Chevy/Mercruiser (Alpha 1).<br /><br />It's the purple wire coming out of the wiring harness (w/ the 2 red wires). Looks like it's to be attached to the distibuter w/ the black wire (black wire w/ the yellow connectors is a jumper that's going from the distributer to the negative side of the coil).<br />Thoughts on the purple?<br />Does it go to the distributer terminal w/ the black wire?<br />Not any other options I can see given the limited length of the wire?<br />Tachometer lead I assume?<br />
CZSteve
Re: Help - Wiring?
Laddies,<br />Thanks.<br /><br />But, the purple wire is WAY too short to reach either coil terminal (assuming the coil had been rotated). This part of the wiring 'appears' to be stock factory.<br /><br />I had taken detailed pics of the motor before disassembly and what you see in the pic is as before. The previous motor started/ran without a problem, don't remember if the tach registered though.<br /><br />Questions:<br />Is the black jumper correct? ie: Distributer terminal to negative side of coil? (just as was when I bought the boat)<br />What is the purple? Tach?
Don S
Re: Help - Wiring?
To find out what wire that actually goes to, you are going to have to get a wiring diagram for whatever Mercruser model number you have. The link that Ralph gave you won't work because they changed color coding way after your engine was made.
CZSteve
Re: Help - Wiring?
Don,<br /><br />Where's the best place to get a wiring scematic?<br />Local marine parts? I assume.<br />Online?
