Help wiring up 3 batteries.
jt42513
I have a 2011 Searay 185 sport with the v6 engine and 60amp alternator. I just put in 2 amps 8 speakers and 2 subwoofers.
Im getting (2) additional batteries for just the audio system and leave (1) stock battery to start the boat. 3 batteries total.
What is the best way to wire these up? I know the boat alternator probably wont be able to charge the 2 additional batteries fully, but some charge will be better then nothing.
Option 1: Leave the 2 batteries completely separate and just charge it when i get home?
Option 2: Hook up a perko switch and/or acr switch to get some charge? Then top it off with external charger at home. How would i do this? what do i need to buy?
Im leaning more towards option 2 because i wouldnt want the 2 batteries to completely go dead out at the lake.
Any help would be greatly appreciated.
Thanks.
Silvertip
Honorary Supreme Mariner
Re: Help wiring up 3 batteries.
You follow the directions with the switch and/or ACR. You will need to parallel the two house batteries.
jt42513
What should i get though? A switch and acr? Or either will be fine? I heard of people getting both?
Yes, im going to wire the 2 house batteries in parallel.
Silvertip
What you get depends on whether or not you understand how to use a dual battery swtich. If you do, then you don't need an ACR.
