help wiring jvc kd-ar860 to sub and amp
Wezzy63
I had problems finding ground under dash so radio is wired direct to battery ans wired to speakers works great. Two things not sure just what gauge wire I should connect to battery and then i am wanting to listen to radio with out boat on what is the easyiest way and cheapest to connect from start to finish adding 12in sub and 400 amp. I have no wiring harnes wiring each line and red power in has no fuse, is this a have to and what size do i add to this. Thank you so much
Fl_Richard
Re: help wiring jvc kd-ar860 to sub and amp
There is a difference between what will work and a correct installation. Hooking up and installing are two completely different animals. Which are your trying to accomplish?
If its a little 50wx4 stereo 16 AWG should be fine for the power wire feeding the stereo. This wire should be fused at the battery side with a 10 amp fuse. The stereo itself should have a smaller fuse holder that contains the specific size to protect the stereo itself.
Amps and subs.... Your on your own, real marine stuff is expensive, even the cheap stuff is expensive compared to automotive. That's because its marinzed to hold up better in the extreme marine environment. That said even the cheap marine stuff doesn't last too long.
If you use automotive components expect them to not last more than a couple of seasons IF well taken care of.
Hope this helps!
