Help wiring 1995 DT 25 monitor
Status
Not open for further replies.
connellyjf
Hi:
I'm having trouble figuring out how to wire the monitor on my DT25. I've got the monitor hooked up and the harness run back into the engine but cannot find a plug with the correct wire sequence to plug into. I've found two plugs that it will fit but the colors don't match the wiring diagram in my owner's manual. I tried it in one of the two plugs and the monitor lights came on but when I turned the key off the engine wouldn't stop so I unplugged it and set it up the way it was....
Any help greatly appreciated..
Thanks.
Jeff
schoir22
Did you ever figure it out? I am having the same issue. The plug for the oil sensor is different from the cable from the monitor.
Status
