iwannagofast
- Jul 26, 2007
- 42
Attached is a picture of the parts I have. I took off the housing attached with the two hoses and though I should take off the rectangular piece you see in the picture. Bad Idea the whole thing flung out at me and now I'm not sure what goes where I'm sure I have the plastic piece in the whole in the right direction I think that the other plastic piece sits on top of that flat side down with the ball side that should sit in one of the two springs but which spring goes where. I also put my thermostat in boiling water and the little pin on the end came right out. Plus do I need a new gasket for that part or is the old one ok to use. Or is some high temp gasket maker good enough...
