Fellow IBoaters,
I bought a used boat awhile ago that is equipped with a 40 hp, 4 cylinder, 2 stroke, 1995 Mercury elpto (oil injected). The boat and motor are in immaculate condition with only one problem...the motor starts really hard. Once it runs a bit it will go all day no problem.
Went to a local marina and they suggested that it was a choking problem where the choke plates on the carbs were not closing completely and therefore allowing too much air to start it cold. I hold the key in to prime it, set the shifter, etc. and sometimes it takes 10-15 turns before it will finally fire up. I got some Mercury fuel additive and am going to see if that helps at all. I wondered if it might be old or bad gas because the boat sat through the winter before I bought it (he said fuel stabilizer was in it though). Also, bad gas wouldn't explain it running like a top once it gets warmed up.
I also made the mistake of using starter fluid to start it once until someone told me never to use starter fluid cause it can damage motors without lubrication. They suggested I buy a spray bottle and pre-mix the gas/oil and use that to help start it.
Does any of this all sound familiar or correct to all of you? Does anyone have any other insight into this issue with this or a similar motor? I don't want to drop a bunch of money on a celenoid or something else to fix the problem if I don't have to. I am taking it back out today and will look to see if the choke plates are closing or not.
Thank you all in advance for any ideas you might have,
JS
JS
