Re: help w,eagle cuda-168
In your driveway there is no water so whatever the locator says will be wrong. The transducer needs to be in the water. What readings do you get in the water. A Cuda doesn't have very much adjustability so sensitivity is about all there is. Set if for about 75%. Then go to a spot where you know how deep the water is and see what you get. You do have the transducer positioned correctly don't you? If this is a "skimmer" transducer, the tapered (pointed) end points forward. The Oval shaped end points rearward -- not down. If you can't figure out the settings from the manual you have a bad unit or a bad installation. If you don't have instructions, download them from the web site.
