Need help please. This thing is driving me crazy! This is what I have tried.
Compression 150psi all four cylinders.
Replaced distributor
Plugs & wires
Removed exhaust elbow & intake exhaust and water tested for cracks and replace gaskets
Removed burnt exhaust flapper
Replaced wore out camshaft and lifters.
Everything I have done made it better but I am still left with a small amount of a pop when first second of starting and when I get above 3500 rpms the popping thru the carb gets really bad and I start to loose power. The engine does not like to idle real well but just off idle all the way to 3000 rpm runs great. This engine has had a water pump failure in the past and has been hot enough to melt the hydraulic lines going the trim cylinders oh yea replace the lines also. This boat ran ok at first of season up until 4th July.
Questions
What is sticky valves or valve pop?
What will wear the cam exhaust lobes off of #3 & #4 cylinder?
What happens when you have a small crack in the water jacket in the exhaust leaking into the exhaust port?
What will cause one not to run good on factory set timing. I have to set by ear before run well from 1200-3000rpm. Just like old days.
Thanks for any help
Plugs & wires
Questions
Thanks for any help
