brettagostini
Thread starter- Joined
- Jul 14, 2003
- 77
Hi... I have a 78 Evinrude 140. Lately, if you drop back to the neutral position, the prop still turns. To truly get it into neutral you have to pull back into reverse just a tiny bit, then go forward again to the neutral position. Sometimes you have to try this several times to get it into neutral. This is a real safety issue, so I wonder if someone could help me out. Do I need to replace a cable? Adjust something somewhere? Lube something... ?<br /><br />Thanks!!
