Help! Too much Ring Free added to tank!!!! I don't deserve nice things...
Parkeway
Ok, careless idiot here...how's this for a first post?
I recently purchased a 32oz bottle of Yamaha Ring Free (Plus) and while out on the water, accidentally let 24oz(!) go into the tank ? I was planning on doing a shock treatment before putting the boat up for the season. I pierced the seal with my thumb, turned the bottle up, and before I knew what happened, 3/4 of the bottle dropped in, followed by a few choice words (strung together in an incoherent rant about being an idiot)
I had 21 gallons of gas in the tank, and fearing I would damage the engine (SX200TXRZ), went to the dock and immediately filled the tank up to its maximum capacity (80 gallons) to dilute the Ring Free as much as possible.
My question is, should I have the tank drained to prevent damage to the engine or keep running/topping off till things get so diluted it is no longer a concern? Obviously after this fiasco I will replace plugs ? anything else I should be worried about?
Thanks for your help,
Parkeway
2001 Yamaha OX66 200
robert graham
Re: Help! Too much Ring Free added to tank!!!! I don't deserve nice things...
Parkeway
Well, the Ringfree "deposit removal" dosage is 2 ounces per gallon, so you'd need 160 ounces in 80 gallons of fuel to clean/remove carbon...so where's the over-dose problem? Just run it like it is and don't worry about it, but remember to add your Stabil before winter lay-up. Good Luck!
