Ok, I recently purchased a boat (1988 Larson Senza V22 w/ SBC) which I found anti-freeze in a cylinder and cannot get it to turn over so i'm seriously thinking of RePowering it with a long block from RapidO Marine. Does anyone have any experience with RapidO marine? If so, I would love to here your comments good or bad regarding customer service and quality of product. Do these motors turn rated HP? I would also like to swap my intake out for a 4 barrel intake and a good carb, can someone point out some good casting numbers or links to a good carb/intake combo. Also, not knowing the history of the boat and not being real familar with marine mechanics I was also considering a rebuilt outdrive off eBay at this time and installing it along with the new engine to ensure plenty of trouble free hours ahead. Now I can do the above mentioned package at a price of $2,700 with me performing all the labor. This seems so reasonable that I think this is a positive solution, correct? Is there any other things I should check out either on the engine or outdrive before I pull them and possibly list on eBay w/o a reserve so buyers have a better idea of what they are actually getting? Do you guys recommend anything other than the above mentioned package at this time to a new boater on tight budget? Can someone recommend a solid prop for a fresh water reservoir boat that will be driven recreationaly? What tools will be needed during the swap? What other parts should be replaced at this time that won't included with the long block and outdrive? Any links to tools, parts, and installtion instructions would be greatly appreciated.
-Thanks
1988 Larson Senza V22' Chevy 5.7 ltr 350 mag w/ Mercruise outdrive.
-Thanks
