HELP!!!! puncture in unpatchable area NOOOOOO!!!
Eric Fife
Hello all
i have an intex mariner 4. i put a hole through the welded rubber attachment point for the motor mount on the back of the boat. its right up against the rubber ring where the metal bar of the motor mount attaches to the rubber ring. the hole goes through the rubber welded piece and into the boat. intex can give no help on this. im thinking either a tire plug or rubber cementing a screw through the hole to fix it. does anyone have any suggestions?
thanks in advance.
Sea Rider
Welcome to Iboats,
Post a pic of the issue, better than 100 written words...LOL!!
Happy Boating
spend another $200 on a new boat?
Bonaventure
Do you use the motor mount?
How on earth did you do this?...Sorry........
Piper36
I've successfully use cycle tubeless tire sealant for fixing minor ignoring leaks, may not work in your case.
Pour bottle about 250ml into dry tube, avoid getting in valve, I used a hose and syringe and put hose through valve so it went straight into pontoon. Inflate pontoon and rotate boat so sealant can cover the leaks. In my case pontoon was going soft over a couple hours, now it is rock hard overnight, never been that good before.
Mountain bikers use plugs (see bike shop) for big holes with sealant doing rest. I've not tested it but worth a try.
alanfox55
Is your boat pvc? If it is it can be patched. Go to the NRS web site,they will have all the material needed to do a proper patch job. They also have video's and will be happy to take your call if you need to. Good luck.
Sea Rider
It's proper time to spend wisely on a more pro inflatable boat with a built aft transom that will last and enjoy much longer compared to a flimsy cheap one made out of a un supported shower courtain material...LOL!!
Happy Boating
Eric Fife
actually i bought a 12.5' meyers vhull aluminum. a tire plug fixed the puncture btw. just sold the inflatable not to long ago.
