Help... poppet valve
sunfighter
I have a 150 merc 2 stroke and while changing the poppet valve, the inside grommet fell into the engine.(sigh... never ends) any ideas on how to retrieve it. item #17 in pic.
Thank you in advance.
wired247
If you can shove your finger down that hole it doesnt go far. Ive pulled one up to the point I could grab it with a pair of needle nose pliers. No, Its not any fun. A shop vac over the hole will do it too.
sam am I
No Title
Not sure if this will help but sometimes helps to know the nature of the beast.........
sunfighter
Thanks guy's. the pic helped explain a lot, and the vacuum idea is one I'll try tomorrow. My stubby fingers couldn't reach in far enough. :)
And thanks to the moderator for removing the double post. I could not figure out how.
Dukedog
Sometimes tha tried and true 'ole coat hanger will get it..............at least up ta tha hole so ya can get hold of it.
sunfighter
Good idea Dukedog... now if I can just figure out how to un twist one of them plastic hangers. :laugh: :laugh:
